OK some info is missing
Truck maxes out towing at 7200
what is trucks payload cap?
A 7000 lb trailer should have a tongue weight of about 1000 lbs, do you have the payload for that with other passengers, gear in bed etc?
You use the truck as a daily driver, and dont want a 3/4 ton. But another F-150 properly equipped can tow 10700 and carry up to 2300 lbs. So the possibility of upgrading to an eco boost with higher capacities is available should your current truck disappoint you in its towing after a few trips, or if you decide to make some longer , more ardurous trips in the future.
