jhelms89 wrote:
lawrosa wrote:
Tongue weight will be your issue. Post what trailers your considering
passport 2920bh
http://www.keystonerv.com/passport/models/2920bh/model-mobileLists a 625 hitch weight.. I bet that will be up in the 850lb range.
I started with 541 hitch weight on my camper and ended up at 740lbs. 14%. And I try to run light.. Thats with propane full, another batter, all my basic stuff in the passthrough.
Thats without food, water, and cargo ( clothes for 4 under front queen)
Just an FYI on how the TW works.. Sure you can do it with WD hitch. Watch what you put in the truck.
I think you may be sagging some in the back of that truck. Like my 1500 in my sig.. I added sumo springs. That helped significantly..
But another issue you may have being at max is trans temps. Maybe even engine temps.. I think you posted you have the smaller v6???
I added the largest trans cooler I could fit. Even towing 5500 - 5800 lbs fully loaded, thats a lot of weight. I started at a 4700 lb trailer.
So upgrade what cooling you can, probably will be looking at something to stiffen spring pack..
Thats all I got for you. But verify the engine you have?
