campermama
Oct 08, 2019Explorer II
whiteeye42 wrote:
you buy a hose and cut it so you a a section of hose with the correct fitting to hook up to your trailer then place the cut end into the jug of antifreeze and turn your pump on and it should suck it up as long as you have the valves in the right position
And then does it pump it through your system from there? So you turn on faucets inside and let it come through? Thx!
44,071 PostsLatest Activity: Aug 30, 2026
