enblethen
Aug 22, 2014Nomad
Booster is located in the antenna head.
The switch is on the power supply that induces 12 volts DC onto the coaxial cable.
Does the red/green LED come on?
It maybe a bad antenna head/booster. Disconnect the antenna from the head. Check between center conductor and the outside shell for 12 volts DC.
You could disconnect at the power supply first to make sure the `12 volts is leaving the power supply.
44,056 PostsLatest Activity: Jan 12, 2020
