kennyzzz
Jun 11, 2015Explorer
anti-hitch rattle, homemade
[img]http://s17.photobucket.com/user/kennyzzz/media/Mobile%20Uploads/20150611_102311_zpsxv8fw0qf.jpg.html?filters[user]=7254396&filters[recent]=1&sort=1&o=1[/img]
I purchased one of the anti rattle hitch devices, you know the things that are supposed to stop your hitch from rattling around.
the one I purchased did not work campground is only 20 miles from the house when we arrived the anti hitch device was loose, I tried front ways back ways no matter which way I positioned the 4 screws it was always lose when we arrived back home 20 miles later so this is the concept I came up with 2 pieces of aluminum, but this is the only stuff I had around, 2 5/8 grade 5 bolts.I put beveled angle on top piece in a small angle on the bottom, on the bottom one I have a piece of flat steel with a slight filing I wanted to give it a little bit of angle, took machine shop in high school would love to have a vertical mill would make things so much nicer but this should work of course I haven't tested it yet but just wanted to show my homemade anti-itch device. I know it looks Jimmy rigged it should work.
I purchased one of the anti rattle hitch devices, you know the things that are supposed to stop your hitch from rattling around. the one I purchased did not work campground is only 20 miles from the house when we arrived the anti hitch device was loose, I tried front ways back ways no matter which way I positioned the 4 screws it was always lose when we arrived back home 20 miles later so this is the concept I came up with 2 pieces of aluminum, but this is the only stuff I had around, 2 5/8 grade 5 bolts.I put beveled angle on top piece in a small angle on the bottom, on the bottom one I have a piece of flat steel with a slight filing I wanted to give it a little bit of angle, took machine shop in high school would love to have a vertical mill would make things so much nicer but this should work of course I haven't tested it yet but just wanted to show my homemade anti-itch device. I know it looks Jimmy rigged it should work.
