wcjeep
Aug 03, 2014Explorer
If you're running Stable Loads try lower air pressure in the bags. Air bags tend to unload the suspension. 45psi? The Swaybar does make a difference if your vehicle isn't already equipped. Can't answer if you need it or not. How much weight on the rear axle? Tire capacity? I found my sway bar on Craigslist. Previous owner moved to next generation truck. He parted out all the extras.
44,071 PostsLatest Activity: Aug 30, 2026
