fla-gypsy wrote:
djgarcia wrote:
APT wrote:
I highly recommend getting a WDH with integrated sway control. Equal-i-zer 4pt, Reese Strait Line, Blueox Swaypro are three with very favorable feedback.
X1, with an integrated sway control, "you have everything to gain and nothing to loose". With out a sway control you may find when you might really need it due to winds, passing trucks, bad road conditions or just before an accident is about to occur that it is too LATE:( Give me an ounce of safety prevention any day! Cut down going out to dinner a couple of times a month:)
X2, you'd be silly not to get a superior integrated system as mentioned above.
I think the real silliness would be to spend a bunch of money unnecessarily. Especially for something as dubiously effective a "Sway Control"
To the OP:
Hook up your trailer and tow it before you buy anything. Look at how it sits with your truck. A WDH MAY be in order depending on how your F150 is set up. Make sure you have Lt tires on your truck. Make sure your trailer tires are at full cold psi. Load your trailer correctly to achieve the proper tongue weight and drive it.
NO trailer "sways" inherently. Sway is most often a driver induced phenomenon. If you load and drive your trailer correctly you will likely NEVER experience "sway" at all.
