handye9
Jun 09, 2014Explorer II
That's a lot of trailer for your Titan. I know it's got the power (I used to have one) to pull that, but, it's lacking a bit in payload, curb weight, wheelbase length, and probably doesn't have the tires to support what your're carrying.
That new trailer is 6700 lbs (dry), with 700 lbs (dry) hitch weight, and it's 35 feet long. Loaded up for camping, it will be about 7500 lbs (possibly more) with tongue weight close to 1000 lbs.
Depending on trim level, cab configuration, drive train, etc, your Titan's max tow rating could be 7400 lbs. Nissan advertises up to 9500 lb rating on Titans, but, not all Titans are created equal. The key words being "up to".
I've towed a trailer, similar in size and weight to your new one, with a Nissan Titan. It was not a pleasant experience. If the weatherman predicted "breezy", I could expect some tail wagging the dog.
If you're towing with a single friction sway control, that's deffinately not enough.
Blue Ox Swaypro, Hensley, Propride, might help, but they won't fix being overloaded or exceeding your ratings, if that is where you're at.
