CLHEJ
Feb 06, 2016Explorer
Anderson anti sway hitch
Anyone use or have experience with this hitch. I currently have a Reese dual cam, but thought about upgrading to the Anderson hitch on my new camper.
Thanks!!
Thanks!!
CLHEJ wrote:
Thank you BarneyS. Yes, that is the setup I currently have. I do have a bit of work to do prepping my old unit for trade, so I will remove the Dual Cam and put it on my new TT when I take delivery.
Thank you again for the advice.
Craig
CLHEJ wrote:
One last question regarding the Dual Cam. The one I currently have is approximately 15 years old. I'm getting ready to trade my TT in on a new one. Should I consider upgrading the Dual Cam, or are there really no upgrades to the newer versions?
Sorry for the dumb question, but just curious if there are any major upgrades to newer Dual Cams.
Craig
GrandpaKip wrote:
I have used the Andersen hitch for 2 years on 2 different campers. I really like it for the reasons stated above. However, I would be concerned about using it on anything with a tongue weight above 700 pounds or so. Then I would want some definitive experience from other users at those weights. For smaller and lighter campers, the Andersen is the best choice as far as I am concerned. Easy to use and set up. Neither camper showed any slip problems on the tongue and, so far, no problems with the taper and brake material. Overall, it has worked exactly as advertised.
