camperforlife
Jan 07, 2018Explorer
I was in the plant in '04. If I recall correctly the roof is an aluminum tube frame with Styrofoam sandwiched between plywood. The floor is the same. The walls are the same aluminum frame with Styrofoam sandwiched between filon exterior and the paneling on the inside.
