hybrid_dw
Jan 28, 2018Explorer
So we are nearly in a prepared state to patch, we still need to remove some of the rotted luan layers down to adhesion. I plan on installing FRP in place of missing luan/wood, directly adhered to the foam. The foam is intact so it will hold. Why put back a material that is again vulnerable to water damage (should it ever happen)? Using FRP will provide stiffness and super flat surface for the membrane to adhere.
