Desert_Captain
Sep 24, 2013Explorer III
n7bsn wrote:
Your experience sounds similar to mine. I actually usually avoid tow-haul mode going down grades for this very reason. I also leave it off if the road is level and flat.
If I am in a situation where I am going up/down lots of small grades I often leave it engaged the entire time.
Why in the world would you avoid TH on downgrades? That is the best feature on my V-10 5 speed tranny. I can cruise down a ten + mile 6-8% grade and not only never touch the brake pedal and I am burnng Zero, Zip, Nada gas!
Uphill it changes the shift points to more eficent moments, that towhaul is smarter than you or me and you should use it often.
44,056 PostsLatest Activity: Nov 19, 2013
