lawrosa
Apr 09, 2018Explorer
wnjj wrote:lawrosa wrote:
This is pulling large grade in NCaroline up the smokies with a 5.3 pulling 5500 lbs trailer fully loaded. I dont floor my truck ever. I let the engine work.
1st gear 30 mph and 3500 rpm.
Infact I take my foot off the gas some to keep at 3500 rpm.. Remember I have 4 speed..
Notice engine temps 230f but trans temps with cooler 175f or so.
https://www.flickr.com/photos/93289479@N04/35822079640/in/datetaken/
And this is 2nd gear trying to pull highway grade. Im trying to not let it go into first gear.
30 mph and 2200rpm. Second gear is a dog if you don't get momentum for the hill. But there is nothing you can do. I couldn't speed up.. I could just maintain..
Imagine if I towed 7500 lbs as Chevy says I can??? LOLOL ha ha ha
https://www.flickr.com/photos/93289479@N04/39374281641/in/datetaken/
Lugging at 3500, you’re leaving a lot of HP behind. Spin that motor up a bit. When they spec the tow rating, Chevy probably assumes you’ll actually let the motor run instead of holding back on the go pedal.
Hardley lugging @ 3500 rpm. Im right in the torque band. Why gas it up and rev to 4000 to go 5 mph faster. If I let it shift to 2nd it will dog and kick back to first anyway..
I wasnt struggling in that first video. I was just letting the engine work, and that was a comfortable RPM and speed for me.
Since the 4l60 trans has such a low 1st gear I can pull any grade with 6000 lbs on the hook. Not fast but it will do it.
But as in the second video I was lugging there a bit. It was an in between 1st and 2nd gear thing... Oh I wish I had a 6 speed, but it is what it is...
But to the OP, you will be fine IMO.
44,072 PostsLatest Activity: Aug 30, 2026
