NanciL
Mar 18, 2016Explorer II
Guy Roan wrote:
Simple solution that works for me.
I never had a problem with my first trailer, but with my second one I had the exact same problem.
Prior to raising it to take it off, just remove the safety pin and the large pin that holds the hitch to the receiver.
Then as you raise it, this allows the hitch to slide back enough to release the pressure that is holding it and it will come right off.
I always leave one of the safety chains attached to the TV, until it is up and off the ball, and then I chock it and remove the safety chain.
Guy
Same here.
I got that idea from here about three or four years ago, and now I do it every time and it works perfectly.
Jack L
44,056 PostsLatest Activity: Jan 12, 2020
