- travelnutzExplorer IIBTW, we live right across Lake Michigan from you and had pulled the 30' to Florida and back many times and never had a power issue nor should you. Right down I-65 and a couple times down I-75. Also pulled it with the 1988 Chevy 2500 van conversion to Yellowstone which is bucking a prevailing head wind all the way and still no problem going 65 mph.
- travelnutzExplorer IIdrsolo,
Your 1992 2500 GMC van most likely has the 5.7 liter V8 and it has plenty of power to pull double the weight of your Wildwood trailer. A slim possibility your van has a smaller size V8 because few of them were ever sold in the 2500 model and usually only in the short wheel bsase version. The unknown is what rear end ratio your van has as that will make a huge difference in pulling ability. Most had the 342 or the 373 ratio as OEM. Yours, being a camper van conversion and the long body version, most likely has a 5.7 V8 with either the 342 or 373. You'd know if you purchased the van new but if bought used, who knows what may have been changed since new. The other power robber is an mostly plugged catalytic converter as your van is now 24 years old. OR the engine cylinders/rings are worn and losing compression.
We had a Chevy 2500 Deluxe Starcraft Van Conversion and had no problem pulling a 30' Nomad Century trailer loaded with options and full water plus all our food and stuff which is more than double your trailer's weight and it had the same front shape as yours which is far from aerodynamic in shape/wind bucking. I could pull the trailer at 70 anytime except up hills or long steep grades.
Have your van's engine checked and the catalytic converter also as it should pull your Wildwood at even 70 mph easily without flooring the go pedal. Something isn't right with your van and will need to be fixed anyway so you'll be paying double plus in the long run by having your Wildwood delivered since the van needs to be taken care of also.
However, remember that your trailer tires have a max speed of 65 mph even if they are 225/75/15 "D" range tires (8 ply rating and 65 psi max inflation) and less than 65 mph if they are smaller tires than those with 50 psi max. - ChooChooMan74ExplorerI remember you. You just bought a bigger trailer. As others would say, it would cost a lot. If you were going the other way, you may find a hauler to back haul it part way or all the way cheaper. You don't have many choices. Stick it out and take it slow, or not go with it.
- towheadExplorerBy "hard time" what do you mean? Your van should pull that little thing easily. Does the van need a tuneup and seem underpowered or was the trailer fishtailing or overloaded?
- azrvingExplorerThat's a sweet little trailer. Could you take the back roads? It seems like your van should pull that. Were you on the expressway?
- colliehaulerExplorer IIIYour van should be able to pull a small trailer like that without any problems. I would have someone check your van. To have it hauled would be price prohibited at $1 to $2 a mile.
- drsoloNomad
flguppie wrote:
Why not rent a U haul truck and tow it down yourself? Are you planning on leaving it in FL?
My van is actually my RV and I am leaving the TT in Florida but for use by friends and family. I use the van. - FLGupExplorerWhy not rent a U haul truck and tow it down yourself? Are you planning on leaving it in FL?
44,056 PostsLatest Activity: May 04, 2014
