nohurry wrote:
Jackfate wrote:
This being my third tt , they just keep getting higher. One thing I know is the higher it is the worse it handles. Even a n inch would helpful . Change springs? Shackles? I know people lift them. I understand theirs limits.
Just wondered
Does yours handle badly?
If so, it likely isn't the height. Might check hitch weight, and setup, and/or weight distribution in TT. Anyway, as has been said, the floorplan has dictated your trailers height. Whether it be a slide, or just an open floor space above the wheels, it was designed, and engineered that way, and I wouldn't try to change it. Good luck.
The higher you make it the more Wind effects it
