Huntindog
Mar 03, 2020Explorer
LarryJM wrote:Huntindog wrote:trail-explorer wrote:If you balance them.... Be sure you have them use a lug plate. Otherwise it is a waste of time and money.Griz14 wrote:
Thanks everyone for your feedback. It looks like the Goodyear Endurance is performing well so far. So I going to put them on the my travel trailer.
Be sure the tire shop balances them.
Lug plate or not IMO balancing trailer tires is a waste of $$$ in general. ;) However, it's your $$$ so do with it what you want :B
Unless you use shims in the wheel hub pilot to center the wheel on the axle before tightening the lug nuts, you will never center that wheel on the axle with any consistency. The first two or three lug nuts you mate to the conical wheel seats will shift that wheel off axis if you don't use shims which is a HUGH and TEDIOUS procedure and having balancing wts already on the wheel can potentially make the wheel even more UNBALANCED on the axle than if the wheel had not been balanced on a machine using a lug plate.
Larry
That is not the problem.
The problem is that the so called pilot center hole is not necessairily perfectley centered on most trailer wheels. They are just stamped out. They are not meant to be centered on the hub by the pilot hole. They are called Lug centric, for a reason. The lugs center them. Now a lot of autos use hub centric rims. Those can be balanced using the center hole when balancing.
