hohenwald48 wrote:
We just purchased a small 2014 Jayco 22FB TT with tandem 3,500lb axles, an empty weight of 4503lb, tongue weight of 510lbs (according to the specs). I'm towing with a 2013 Nissan Armada with a 9100lb towing capacity, 910lb tongue weight rating, 15100lb GCVWR and auto leveling rear air bags. I have a friction sway bar also. We will just use it for short trips so it shouldn't be loaded up with a lot of junk. However, it does carry 90 gallons of water directly over the axles. I will probably limit the water load to about half full or around 400 pounds but since it's directly over the axles it should not impact tongue weight.
Is there any reason I should consider adding a WDH to the mix?
I have only towed it for about 20 miles home from the dealer so I don't really know how it will tow in the long run. Didn't hardly know it was back there on the way from the dealer.
OK folks you convinced me. I picked up a Eaz-Lift round bar 1,000/10,000 WDH at Camping World and intend to use my existing friction sway control. I know there are probably better systems out there. However, since I'm towing at about half of what my TV ratings are I didn't think I would need the very best top of the line hitch/sway system. Thanks for all the information and input and I'll post back after I've had a chance to see how things work.
