- janglesExplorerThanks guys , problem solved , sold the camper !!
- whizbangExplorer IIYour propane tank ran empty???
More details please. - s1214Explorer"Depending on specific models, there are two things common to those 3 items, 12 VDC and propane. If either is missing they wont work.
Like he said. If your stovetop is working then you can rule out a propane issue. My old Sun-Lite's furnace and 3-way fridge would not work if the battery was removed or dead. - rexlionExplorerCheck your circuit breakers and LP supply.
- Mandalay_ParrExplorerCall a mobile tech if need be or find an electrical person to help you.
- jmckelvyExplorer
jangles wrote:
Truck camper fridge, heater and the hot water heater quit working all at once . What the heck would cause this ? Battery ? fuse / I'm lost . thanks for looking .
Can you provide more details? Are you plugged in to shore power or not? Does your cook top work? If so I would concentrate on the 12 VDC and make sure it is good. If not check for blown fuses, bad connections, run down battery, etc.
44,056 PostsLatest Activity: May 04, 2014
