jmcgsd
Oct 26, 2015Explorer
Kayteg1 wrote:
Did you have your axles weighted?
From what I learn about TC is the last thing you want on them is put heavy stuff in the rear and have front axle lifting off the ground as the result.
Believe me that isn't an issue with an older unit like this on a Dually. 50# more on the back will make no difference. This camper grosses at least 800# less than the Lance 981 I carried for nine years on the same truck. Yeh the battery will change the axle ratio slightly but not enough to notice. If it does I can always balance it with a couple of cases of beer in the back seat of the truck. ;)
