narcodog
Oct 27, 2015Explorer II
I built a rack, actually had someone else weld it. Installed it under the passenger side wing of the Lance. Used 4ga marine grade cable and Anderson connector. The battery is a group 31 AGM mounted on it's side. I took a battery box and cut it so it would protect the battery from flying rocks and such. I have use this set up for about 6 six years. It being an AGM, I don't have to worry about water or ruff handling. I check the battery connections about once a year to make sure they are tight. That's it.
