Gdetrailer
Mar 16, 2018Explorer III
SoundGuy wrote:Gdetrailer wrote:
Typically in RVs the bed length IS short and finding any bed in standard home lengths is almost impossible.
Well there are notable exceptions ... the current Coachmen Freedom Express travel trailer series features full 80" length queen beds as do most models in the Coachmen Apex series. :BGdetrailer wrote:
Even the so called twin beds are not as wide as your home bed, so a FULL size bed is a bit closer to what you seek.
Home twin is about 40" wide, RV twins are on the order of 32-34 wide or about what a home couch depth is.
Sounds to me like the OP is looking for an east-west bed in a twin size, which I doubt he'll find as most seem to be 54" "double" width ... lots of those out there. :)
Which is why I specifically mentioned TYPICALLY RV beds are short. That means there may be a FEW "exceptions" but in reality MOST will be short.
RVs by the very nature, is a small space, to make the most of the small space there ARE compromises that MUST be made to fit in all the amenities that the wider audience DEMANDS.
Op IS going to HAVE to make a few "concessions" in their DEMANDS if they want to buy a RV.. Bed width IS a concession that should not be a show stopper at all.
Doubt the OP has ever tried to sleep on a RV twin bed.. Try sleeping on a couch for a few weeks.. That IS the size of most RV twins..
I would shoot for a Full size bed in a RV, it will be slightly wider than a home twin but not as wide as a home full size.
If the trailer has more beds than you want, ignore the extra beds..
As I mentioned before, RV manufacturers typically do count the dinette as a "bed" since most dinettes the table drops and the back cushions are used to fill in to make a twin bed. Therefore than manufacturer COUNTs that as a bed.. It IS optional so you simply leave the table up and ignore the idea of it being a bed..
Any extra beds, the OP CAN also "convert" those to storage depending on the configuration.. Bunks can often be removed and shelving put in place.. Or one can simply put a curtain up and use the bunks and hide anything there as storage..
Many things you might want to take with you like outside chairs, tables, canopies and such could be stored on one of those unneeded bunk spaces..
Many people often find they are short on storage space, those extra bunks can be put to use..
Many ways to get around the problem if you think outside the box.
I would also think that if the OP ever decided to sell the RV, they WILL have an easier time selling a RV with more than one bed..
OPs best bet is to go to a few different RV dealers and start roaming their lots.. Go in each trailer then think about how they can repurpose or reuse the extra bed spaces.. Shouldn't be all that hard to do.
