Jedidad wrote:
kerrlakeRoo mentioned one with bunk beds that I hadn't thought of (Flagstaff E16BH). Looking at those now. Hard to find models with bunks ONLY and not an additional queen bed. (I'm looking at TT's under 19ft, btw)
Thanks everyone for your replies.
Some beds "convert" into a couch or seating.
Our first TT was a 1980s 20 ft Terry Taurus, the one bed ran across the front and when not being used as a bed during the day it folded up to make a long couch.
The previous owner in their wise wisdom removed the fold up mechanism and dropped a 3/4" sheet of plywood across..
I removed the full sheet plywood, made a small cabinet to fill in the space a bit then made a removable section of plywood that allowed me to turn that back into a couch for daytime. Used a trifold foam futon which allowed to be folded up for couch..
It also had a twin bunk bed over that bed that folded up for day time and down for night.. I ended up just removing that bunk due to severe water damage..
Then the dinette also could make into a twin bed.
Looking for a single bed RV in anything over 16-17ft is not going to be easy, most trailers in that size will have at least two to three beds.
For a single twin your most likely will be looking at the small trailers like TAB (14ft or smaller, think canned ham or teardrop style) which are primarily designed for ONE person or a extremely close "couple".
Like I said, you need to go and look at the RVs on the lot, sometimes things are not obvious from the manufacturers brochures..
