bobndot
Aug 14, 2017Explorer III
This was taken from the Q/A section at etrailer.com
The Solera Power Awning Replacement Motor # LC266149 does not have an installation video at this time. However, the installation is not difficult. Before removing the motor, you want to open the awning about 12 inches and support the arms. This will remove the spring tension in the awning roller for an easy removal. You disassemble the protective housing, remove the bolts that hold the motor in place and then disconnect the 2 wires. To install the new motor, you simply reverse the...
view full answer...
https://www.etrailer.com/Accessories-and-Parts/Lippert-Components/LC266149.html
view full answer...
44,066 PostsLatest Activity: Apr 10, 2026
