closurdo
Jul 12, 2013Explorer
adayjk wrote:
Not only will the speedo be off, but the trans shifts will also be impacted as they are partly MPH dependant. A programmer will be required, and in the event of a powertrain failure may complicate warranty claims (meaning customer pays).
Having done this change before I can say for sure that the speedometer is not effected (at least on my dodge). Changing tire sizes does effect the speedometer though. Shift points also are not effected either. I went from 3.55 to 4.10 gears on my dodge and it made very little difference in towing other than the fact that the truck would stay in overdrive easier. I took two trips to Myrtle Beach from Michigan, the first year I had the 3.55 gears the next year I had the gears change to 4.10 and I can tell you that both trips consisted of about 2000 miles each. I always hand calculate my gas mileage and both trips worked out to 8.6mpg exactly. Point is the difference in towing performance was negligible. Try what you've got first.
44,056 PostsLatest Activity: May 04, 2014
