blt2ski
Jul 16, 2013Moderator
The rockies will test you because for one, depending upon the elevation you are at when there, lets say 10K' like vail pass or the highest point in Yellowstone, with a std gas v8, you will be down 2-3% HP per 1000', so 20-30% on you hp/torque in the rockies! There is NOT a gear ratio change to make up this difference. THe only TRUE real way to fix this is a super or turbo charger on the motor! THen you can get to 10K' or so with out losing any HP/torque from the motor.
My other point, is the rockies have some of the fewest what I would call steep grades that I have found. Other than being long, which can tax cooling systems. For steep hills, ie as I mentioned above, come to Seattle, I can find you steep grades that will stall out ANY truck! yes been there done that, Hence why bridge overpass's do not worry me!
Marty
Marty
44,056 PostsLatest Activity: Nov 19, 2013
