wmoses wrote:
blt2ski wrote:
The rockies will test you because for one, depending upon the elevation you are at when there, lets say 10K' like vail pass or the highest point in Yellowstone, with a std gas v8, you will be down 2-3% HP per 1000', so 20-30% on you hp/torque in the rockies! There is NOT a gear ratio change to make up this difference. THe only TRUE real way to fix this is a super or turbo charger on the motor! THen you can get to 10K' or so with out losing any HP/torque from the motor.
Very true.
So now I am toying with this reasoning .... if I am willing to spend $1000 to change out the rear end, why not consider taking the truck to Hennessey Performance here in Houston and let them put in a supercharger! :D They happen to do drivetrain upgrades as well, and offer a 3/36000 warranty. Consider the smile on my face when not towing ... :D Might even be less money than a new truck.
Reality is, IF the SC can be added, it will do more from a performance standpoint than gears in the pumkins will do! Reality is, if pulled over from an LEO, they do not know, or care what your tow rating is. ALong with they have no way to find out. THey do not even know your gcwr. If you are in my state, they do not care what the door sticker gvwr and gawr's are! I get 500-600 lbs per inch width of tire, as long as my paid for gvw is greater than I weigh, and I have less wt per tire width inch than 500 lbs. You would have to be close to 20K lbs or 10K per axel to be over wt on your rig!
MB in the ML 320 suv my wife has, the tow rating is 5K lbs. We have about a 200/200 motor. I can get an ML55 model, which has a 5.5L V8 with a super charger, putting out in the area of 400/400, and its tow rating is ALSO 5000 lbs! Fine print, get the higher hp/torque motors for better speed performance, for up hills acceleration etc! I can find other manufactures here and there that use the same formula per say for tow ratings. BUT, most seem to use a useless engine/axel ratio BS for tow ratings/gcwr! Which from experience, I have had a truck with a gcwr LESS than its gvwr, go up a steeper grade at 150% of the ratings, meanwhile a BB V8 with over double the HP and 30% more torque, could not go up the same hill at the same wt and 25% LESS than its gcwr. So, do you think I trust tow or gcwr ratings!!!! NOT on you life! pure bonus bogus BS IMHO!
At the end of the day, one needs a tow rig that has the payload for people, other gear, hitch wt etc, proper power and gears in combo with axl ratio and trans, trans IMHO is more important than the axel ratio as shown by the excel program APT has posted! THEN and maybe THEM, you should have a rig that will do what you want it to do. Until them, you may be VERY disapointed in teh R3500 dually with a BB V8, TH400 tranny, 4.10 gears etc, as the worst poj you have ever owned! It could not even out pull a 2500 with a 105HP 292 I6 motor!
So if it were me, I would put the money into a super charger if you are going into the mtns, ie above 5-6K feet frequently. If not, but maybe once in the time you own said truck. Deal with the slower speeds you will be doing in the rockies, and enjoy the view as you go slower!
Marty
