Jfet
Mar 05, 2014Explorer
So which LiFePO4 cells are you using Reed?
To get 13.2V at 720 amp-hours (which would be 9500 watt hours) you would need to use 16 CALB LiFePO4 3.2V 180AH cells which are 12.56 pounds each.
http://www.evsource.com/tls_lithium_calb.php
The total weight of just the batteries would be 200 pounds. Your setup being 160 pounds has me intrigued...perhaps you are using larger cells that are a bit more energy dense?
