loulou57
Apr 04, 2014Explorer
Crawfordville wrote:
Our problem is the edge of the formica is beginning to show signs of separation and with time it will only get worse. Our camper is less than one year old. We have already had them replace a portion of the countertop but we can tell that it will just have problems. I'm figuring part of the problem is that we live in a humid area.
If the laminate was coming away on the edges it could be the glue or it was trimmed too close and moisture is getting in. When you say they replaced part, what exactly did they do? and are you having problems with the fixed area or do you feel that the original may be coming apart? Either way, I would have suggested they replace it all. Since the problem is noted already then it should continue to be a warranty issue.I would not go to the expense of replacing things until all your options with the dealer/manufacturer are absorbed. If the work was done correctly, where you are living should not be a factor.
