PartyMarty
Jan 29, 2014Explorer
The load range E tires have more cords in them
If you go to tire rack and choose 245/75R16 as a size you can then pull down the specs for each tire .
Within a specific brand and model you will see that the Load Range E tire is heavier than the same Load Range C tire and P tire .
I run slightly less pressure in my load range E tires , usually about 50 psi .
