Jarlaxle
Nov 29, 2013Explorer II
blt2ski wrote:
So in reality how many of the van manufactures truly build what "I" would call a 1 ton van....ie a DOT class 3 truck with a gvwr of 10001-13500? most of the vans being discussed here are DOT class 2, ie between 6001-10000 gvwr, or you can split this what I call 3/4 ton category into the LD and HD with under 8400 LDuty and over heavy duty.
Seems to me the NV3500 is a pretty decent van from a gvwr/engine standpoint. No it will not as of yet do what the E350 with a V10 will do, but if you look at this from a gvwr badging standpoint, it is in the mix of ALL the other manufactures of vans with similar engines and remainder of the drivetrain.
Marty
Are ANY of the big vans over 10K? I thought even the E350 and GM 3500's were in the 9000-9750 range?
44,067 PostsLatest Activity: Jun 05, 2026
