Dayle1
Aug 23, 2014Explorer II
Cajun Bill wrote:GOrsted wrote:
If you use a Reese Revolution pin box, the Rambox narrow bed should not be an issue.
Hate to beat a dead horse, but since I've seen this same info on another thread and I'm trying to figure out how putting the Reese Revolution aka Sidewinder on my pinbox would help with the Rambox narrow bed. Doesn't it just slide the pivot point back? Or does it also lift it up enough so that it would clear the bed rails?
Instead of having a +2 ft pin box length pivoting from the centerline of the truck, the pivoting portion of the Sidewinder is much less, so when it pivots it can't hit the truck bed side rails, which are narrower in the case of the ram box. Also, the Sidewinder doesn't attach to your pin box, it replaces your pin box.
