Keith099
Apr 30, 2014Explorer
AlmostAnOldGuy wrote:
I pull 8k and have been happy with all aspects of the rig so doubt I will pursue a tune but if you go down this route please share what you learn. It would be interesting to know what you end up with and if you find a need to harden the drive train or if stock is okay.
Good luck,
Stu
I'll definitely post results. From the homework I did on the drivetrain, it seems that one would have to add more power than the stock fuel system can provide before drivetrain failures would appear, and I'm not even pondering going that far. Really just wanting more low-end torque than anything.
Might even consider a custom tune that boosts power from idle to 3500RPM then falls in line with stock output to redline. It's about usable power, not peak upper end output. No one tows at peak HP RPM's. If they do, it's not for long.
