Fisher_Bill's avatar
Fisher_Bill
Anyone use TorkLift A7200 Stable loads on their GMC 3500?
Hi All,
We took our maiden voyage with our AF 1140 and I've read about air bags and stable loads so I was wondering if guys have put these in their GM rigs.
I've see the load locks where spacers are installed on a lower overload spring assembly but I don't have this set up, I have a six pack of springs on the bottom and above I have two more leafs I think are overload springs.
I'm thinking of getting the load stops where you add a block between the two sets of springs so the overloads engage sooner so it helps level the ride and the hope is to minimize the side to side as well as the front to back sway.
Hope to hear from GM owners so thanks in advance for any replies.
Bill
  • I am currently working with a torklift rep also, have not seen an application for this style I have so far but we'll see what he says.
    Not sure if this will work but I've tried to post pictures of the leaf springs and the camper is still on so they are a bit flexed.
  • I run both. The StableLoads pretension the OEM suspension enough to carry the TC on its own and the air bags level me out if I am loaded unevenly or towing. Either way the main and overload suspension is engaged and the air bags give me infinite height adjustment.
  • Thanks guys,
    Yes I'm looking at stableloads and I'm wondering if someone has them already and if they like them compared to air bags.
    Thanks!
  • If you do not have the lower overload flat leaf spring, look at the upper StableLoads to engage those those upper springs sooner. If the suspension is still too soft at that point, search for Super Springs to supplement your OEM spring pack
  • You will be better served by doing a search on STABLELOADS.
