TJMarc
Dec 25, 2016Explorer
The stuff is actually a rebranded Neste product.
https://www.neste.com/sites/default/files/attachments/neste_renewable_diesel_handbook.pdf
From time to time I will run it, out of convenience for the most part (local and cheap) and have no issues. Couldn't tell if the truck ran any different but I think it might smoke a bit less. One thing to keep in mind is the stuff is dry and needs additives to bring up the lubrication...similar issue we have with ULSD. Also, I recall reading somewhere that the energy density is about 90% of petroleum based and will result in slightly less mileage.
Below is an e-mail that is floating around the forums with a response from Bosch from a fueling system perspective. Basically they have no internal testing and based on other information sources, they have little concern using it in a blend. They do appear to have concerns (seems to be primarily due to lack of data) regarding it's usage @ 100%.
"Dear xxxx,
I have spoken with our fuels experts here in the US and the Bosch position is as follows:
· The ‘Diesel HPR’ is a brand name Propel Fuels Inc. has coined for the NESTE Oil Hydroprocessed seed oil (mainly palm oil) product they call NExBTL. https://www.neste.com/na/en
· This is nearly a 100% paraffinic hydrocarbon material. it has some nice qualities (high Cetane Number, good stability characteristics, virtually no aromatics, et al) but also some significant deviations (lower density, potential cold flow waxing characteristics, et al) relative to conventional Diesel fuel which Bosch products are released for.
· The statement that the fuel meets the ASTM D975 petroleum diesel specification is not completely accurate. They meet most of the specification, but not all of the specification.
· When blended with conventional Diesel we see little concern (even perhaps at blends up to 30 or 50%) because paraffinic hydrocarbons are naturally part of refined petroleum Diesel fuel.
· Bosch does however have some concerns regarding lubricity and its responsiveness to common lubricity improver additives. Refer to notes in the NESTE website regarding lubricity.
Bottom-line: Paraffinic hydroprocessed seed oils (like ‘HPR’) hold promise as supplement to the Diesel pool as blends. Bosch does have concerns for use as a neat fuel (100% blend) and without sufficient validation testing, Bosch cannot guarantee there will not be any performance or reliability issues with our fuel injection systems.
Best Regards,
Ilidio Serra
Robert Bosch LLC
Manager, Technical Service Support (AA/SNA9.2)
2800 S. 25th Avenue - Broadview, IL 60155 USA
Bosch worldwide"
"Dear xxxx,
Best Regards,
Ilidio Serra
Robert Bosch LLC
Bosch worldwide"
44,066 PostsLatest Activity: Jul 25, 2018
