Kayteg1
Aug 16, 2021Explorer II
Ditto on AC taking much less than rated amps.
The ratings takes starting surge into count I guess, but I did measure my AC over the years and from my memory
15k BTU ac run at 8.3 amp
13k BTU runs on 6.3 amp.
When I have never seen real test on inverter efficiency, common knowledge says that it is over 90%, meaning you are not loosing much of battery capacity by using inverter with 120V AC v/s 12V AC
So why spend more money on limited use 12V unit, when you can have 120V unit for less and with much more potential use?
The only issue with using inverter at high load is giving it good cooling.
