andrewwm
Jan 30, 2015Explorer
Anyone with experience towing with a Suburban
Hi, I’d like to hear from people who have experience towing a larger travel trailer with a Suburban. I have a Suburban 1500 5.3L. I want to buy the largest travel trailer my suburban can safely tow. This will be my first travel trailer. I have towed many small trailers and cars on trailers. It will be me my wife and two small children on the trip. We would like as big as we can for space as it will be long trip visiting several towns for weeks at a time.
I’m not so concerned about weigh but I am concerned about length and sway as I’m currently considering a 25 foot outback weighing about 4,500lbs unladen and another 29 foot travel trailer weighing 5,500lbs unladen. If you can give advice from experience on length and sway that would be really appreciated. All advice from experience is appreciated but I’d also really like to hear from those who have towed with a suburban.
Below is an explanation why I’m not as concerned about weights – basically GCWR is probably my limiting factor and I plan to keep within my weight ratings.
Weights – I’ve checked the ratings on my Suburban. From the manual and after checking my gear ratio it has a 7,500lbs max trailer weight and 13,000lbs max GCWR. I had checked on websites such as Edmunds which stated my Suburban would weigh about 5,000lbs. Fortunately, I weighed it with a full tank of gas and nothing else in it but me. The actual weight with me was 5,760lbs (I’m about 200lbs). So before I even add gear to the Suburban/trailer and passengers the max weight of my trailer is limited by the GCWR to 7240lbs.
My rear axle is rated to 4000lbs with tires rated to 2400lbs each. When I weighed it my rear axle had 2760lbs on it. The manual states a maximum tongue weight of 1,200lbs which gives me a trailer weight assuming 15% tongue load of 1200/0.15=8000lbs. So if I don’t put too much weight in the suburban it looks like tongue weight is not my limiting factor. It looks like my GCWR will be.
Thanks
Thanks
