HMS_Beagle
Aug 28, 2021Explorer II
adamis wrote:
Here is an interesting test. Granted, it was done in ideal conditions but still quite impressive. The 100ah Victron LiFePo4 battery lasted for 2 hours and 40 minutes. They are supposedly going to do an outdoor test tomorrow.
https://youtu.be/2LL7lE4wXvs
Interesting test, even if they presenter is completely clueless on just about every aspect of it. Since it was in a closed room with the thermostat set below ambient, it would have run the whole time without cycling (and would be heating the room a bit). I doubt it would use much more outside in hot temps, the high side pressure will increase just a bit. If you added 400 watts of solar you could keep it going pretty much as long as the sun shines.
44,071 PostsLatest Activity: Aug 16, 2026
