Kayteg1
Aug 30, 2021Explorer II
Still how can 400 amp unit be supplied by wires rated for 40 amps?
Meaning between RVIA and Chinese codes used for inverter, the true will lay somewhere between.
In my inverter application, I used the small cable to paralel 2nd battery, when main inverter connection is #2 wire. Just becouse I had it on the shelf and I know that voltage drop on inverters can be crucial.
Still would I build big solar system, not likely I would put 100 lb of cables to connect it to battery.
44,071 PostsLatest Activity: Aug 16, 2026
