Golden_HVAC
Jan 31, 2015Explorer
There is a huge difference between the 3/4 ton and 1500 series Suburban in towing ability. I have a friend with a 2500 series Suburban and 454 inch engine. It tows a 31' travel trailer in the 10,000 pound weight range with ease, and the driver is comfortable.
That is not the same as a 1500 series that is a beefed up station wagon, without the full floating rear axle used in larger trucks. The 1500 would have stamped sheet metal on the front axle, not a cast steel like used in the larger vehicles.
With a 1500 Suburban, then a lighter and shorter travel trailer is the best thing. Also if it is 2000 - 2008, think about beefing up the stock hitch.
Good luck!
Fred.
Good luck!
Fred.
