UTCoyoteExplorerFeb 15, 2014Anything better than plywood for floor?Tackling a "soft spot" in the bathroom project... I've got the bathroom floor all out. The sub floor was 1/2" plywood. Is there a better/best type of sub floor material to use, other than simpl...Show More
QCManNomad IIIFeb 15, 2014If cost is not an issue use aircraft honeycomb laminate with aluminum in both sides and you will cut the weight down by about 75%.
Related ContentAnything other than silicone..replacing plywood roofWould you say anything?Bending plywood for roofAdhesive for Aluminum roof to plywood?
