anutami wrote:
Artum Snowbird wrote:
Wondering whether you are still relying on the Ford vacuum system of 4 wheel drive. After paying and paying to fix it, I put on some Warn hubs and now it works when I put them in every time.
Nice, will look into that.
Thanks
Just so you understand... With the Warn Hubs you have to get out and manually engage each hub, and then remember to take them off engaged when you are done. But, having said that, when you put the dash switch into low range, you now have a terrific low range rear axle by itself. I use mine that way to climb up on blocks and often do not have to actually engage the front wheels to climb up. The seals in the Ford hubs fail over and over again.
