flyrvmiller
May 29, 2014Explorer
Aqua Magic
We have an Aqua Magic Style Plus On occasion, when flushed, after filling the basin, the water sometimes continues to seep in causing an over flow. We replaced the seals and valve. Eliminating the...
On occasion, when flushed, after filling the basin, the water sometimes continues to seep in causing an over flow. We replaced the seals and valve. Eliminating the cowl to be sure there is no possible mechanism bind. Has anyone else had this problem? Also, should there be a water pressure regulator and if so, what would be the maximum water pressure?
Any help would be greatly appreciated.
