Have had one for 2 years. While most believe Northwood is the holy grail of quality. I am one owner that spends more time under and behind cabinets to check everything out. Started bad out of the gate, all 4 brakes were heavily greased (finger pointing on this), 75% of the cabinet hinge screws were stripped, carpet staples were not set deep enough,DC connections were not twisted before crimping, receptacle wire punch downs were done incorrectly(dangerous), loose screw terminal connections on both AC and DC power buss. More sawdust and cut outs in unseen areas than they cleaned up, debris in clogged shower drain, toilet set one inch left and back, lid would not stay up, slide mechanism drive gear not pinned or tightened, A leak around a poorly sealed window, air conditioner plenum wasn’t sealed. I would give this build a C minus. Your mileage may vary. Some will say that is what warranties are for, I say none of this stuff should of happened. The BEST warranty is not needed or used.
WDP
