Troutguy
May 31, 2018Explorer
Arctic Fox 811 Suburban Water Heater No-Light
Hey all,
My Suburban water heater won’t light ......no igniter clicks.....totally silent. I’ve had this camper for 11 years and the WH has always lit and performed flawlessly. Now....I found that the on/off switch has been left on since I put the house batteries in about a month ago. The gas has been turned off since last fall and the batteries were removed at that time and the tank is empty, however I did put the batts in a month ago.
I checked the fuse panel and none of the fuses were marked as Water Heater or equivalent. I haven’t pulled any of the fuses as it looks like I’ll have to pull them all to check. It’s too early to call Northwood and to make matters worse ......the power to the house went out last night and isn’t scheduled to be repaired until 11:30 tonite! The power outage has nothing to do with the AF problem.
Thanks,
TG
I’ll post a pic of the water heater in a little while as my I-Pad doesn’t have a flash.
Thanks,
TG
