Grit dog wrote:
TriBeard wrote:
996Pilot wrote:
13'2" on the back of a 2015 RAM 3500 4x4 SRW MegaCab. That's to the top of the standard A/C and 20W solar panel.
Have you ever weighed your truck? Stock tires? I'm looking to move into a single slide truck camper on my 2018 3500 MegaCab also, and I'm trying to decide between a few different models. I really like the 811, I'm just worried about weight.
You'll be well over most/all the published "limits" and under the practical limits, save for OE tires/rims.
Figure 4000-4500lbs depending on full vs empty and how much you load in it. That's what others report from scales and what I've roughly calced from airbag psi to get to origianl ride height.
That said I've hauled AF 860s (same as 811 basically) on OE 17" wheels and now on OE Ram 20" wheels (on my 07 2500 Mega), both with OE Firestones and slightly higher rated tires. All without issue.
I'm aware that I'm at or a little over the tire's rated capacity.
Couple runs cross country, up to AK, all over AK and the western US mountains including plenty of forest roads and dirt roads. Tires have held up fine.
I'm not too afraid of being a little over ratings (other than tire ratings, and I can go up to the 285/75/18 size on my rims or higher rated ones and get 4080lbs/tire) but I don't want to be at 8k on the rear axle either. Looking mostly at the 811 or the adventurer 89RBS, the artic fox is a little nicer and better looking inside IMO, but the adventurer seems to be lighter also.
