Big_Rig1
Feb 24, 2016Explorer
Nice fix on the slide. I have a 2015 Arctic Fox 990 & I looked in my Owners packet & found that my camper has the Power Gear slide-out system.
The description says it consists of 4 major components.
--Inner rail assemblies are designed to support the room weight.
--A 12 volt DC gear motor will operate the room using power from the on-board unit battery.
--Slide-out systems are equipped with a manual override that allows you to extend/retract the room in the event of loss of power
--A specially designed control that gives the user full control of the room movement, in or out. The control has a load sensing capability that stops the motor when the room reaches its fully extended or retracted positions.
Doesn't mention any rollers so I don't know if this system uses them or not.
Big Rig (John)
Big Rig (John)
