brholt wrote:
There is a potential issue with over filling the fresh water tank. In particular if you attach a hose to the fresh water fill and the water supply has significant pressure you can "balloon" the fresh water tank since the tank vent is not of sufficient size to relieve the pressure. If it is off the truck it will, and some here have reported it, break the tank support ribs.
This is really operator error as the manual explicitly warns about this.
THIS ^^^^^^^^^^^^^
We almost always use ours off the truck when not winter camping. Manual describes the support required for off truck storage/use. It's easy and we like the easier access and less sway.
