APT
Jun 20, 2016Explorer
From the 5 min research on that model, I'd say it's likely to put your Tundra over a few of its ratings. I think the 7500-ish pounds dry seems accurate, which means you'd be in the 8500 pounds loaded with about 1200 pounds of TW. I have never seen a Crewmax with more than 1500 pounds of payload available. Do you as driver, anyone else you plan to bring with you, and a bed full of camping gear weigh less than 300 pounds?
I recommend starting with your as equipped payload as noted on the tire and loading sticker where it says the maximum combined weight of occupants and cargo shall not exceed xxxx pounds. Work back from there to an appropriate loaded RV tongue weight.
