IdaD
Feb 27, 2015Explorer
ShinerBock wrote:msmith1.wa wrote:
I think the problem is you are looking at the wrong weights. If you take the 10,000 lb gross weight minus the base weight you get the payload. The base weight of the 2500 gas vs diesel is about 1000 lbs.
Yes, but the GVWR and whether it is applied due to the 250/2500 Class 2b 10,000 max GVWR limit or due to its actual load handling limit is what is in question. Based on it's numbers, the 2500 CTD is an 11,000 GVWR truck at the very least. It seems Ram (and other manufacturers) give the 250/2500 trucks a max 10,000 GVWR just to keep it in Class 2b which also have less expensive registration costs.
Yep. So the real question is whether exceeding the stated payload matters at all. Maybe it does from a liability standpoint, but then again maybe it doesn't if you're within the axle weight ratings. As far as actual functioning in the real world, the stated payload on 2500 series trucks is meaningless.
